875 -
3
Tout ce qui a été posté par domo
ça commence à devenir bon [DEBUG] 23:55:03: Version API Synology OK [DEBUG] 23:55:03: Chemin API Synology = auth.cgi [DEBUG] 23:55:03: SID API Synology = [LEqTIfHnMVSTQB5G9N00558] [DEBUG] 23:55:05: Memory: 11.642390522927% [DEBUG] 23:55:05: CPU: 0% [DEBUG] 23:55:05: Temperature System: N/A [DEBUG] 23:55:05: Volumes Load: volume_2: 0.03% volume_1: 55.72% [DEBUG] 23:55:05: Déconnexion: 200
et voici {"data":{"offset":0,"total":2,"volumes":[{"id":"volume_1","status":"normal","total":2811987.550,"used":1566967.870},{"id":"volume_2","status":"normal","total":2811987.550,"used":844.20}]},"success":true}
a désoler j'avais pas vu
ben j'ai fait une copie écran du résulta de la deuxième commande tu veut que je clic ou ?
ça fonctionne pas Kana-cha [DEBUG] 22:55:34: Version API Synology OK [DEBUG] 22:55:34: Chemin API Synology = auth.cgi [DEBUG] 22:55:35: SID API Synology = [aLV5khssNG33oB5G9N00558] [DEBUG] 22:55:36: Memory: 11.99598349639% [DEBUG] 22:55:36: CPU: 0% [DEBUG] 22:55:36: Temperature System: N/A [ERROR] 22:55:36: line 192: attempt to concatenate field 'name' (a nil value) [DEBUG] 22:55:43: Version API Synology OK [DEBUG] 22:55:43: Chemin API Synology = auth.cgi [DEBUG] 22:55:43: SID API Synology = [jOnSBBcVNTMtsB5G9N00558] [DEBUG] 22:55:44: Memory: 11.998132403963% [DEBUG] 22:55:44: CPU: 0% [DEBUG] 22:55:45: Temperature System: N/A [ERROR] 22:55:45: line 192: attempt to concatenate field 'name' (a nil value)
Je suis plus chez moi des que je rentre je regarde ça
salut ça fonctionne pas encore merci de ta patience [DEBUG] 18:54:41: Version API Synology OK [DEBUG] 18:54:41: Chemin API Synology = auth.cgi [DEBUG] 18:54:41: SID API Synology = [lubksZAmR4hn2B5G9N00558] [DEBUG] 18:54:43: Memory: 11.895570906136% [DEBUG] 18:54:43: CPU: 0% [DEBUG] 18:54:43: Temperature System: N/A [ERROR] 18:54:43: line 178: attempt to get length of local 'vols_tab' (a nil value)
merci Kana-chan pour ton aide voici ce que ça donne {"data":{"cpu":{"hard_irq":0.0,"idle":0.9848484848484849,"iowait":0.0,"nice":0.0,"soft_irq":0.0,"steal":0.0,"system":0.01010101010101010,"user":0.005050505050505051},"memory":{"buffer":53744,"cached":507628,"free":1229356,"swap_cached":0,"total":2047552},"netflows":[{"name":"eth0","receive":0,"transmit":0}]},"success":true}
On fait ça comment je suis pas un geek
bonjour merci pour cette mise à jour du VD mais j'ai une erreur j'ai aucune info sur l'état du syno et en debug j'ai ça une idée du problème je suis en DSM5 merci [DEBUG] 14:29:15: Version API Synology OK [DEBUG] 14:29:15: Chemin API Synology = auth.cgi [DEBUG] 14:29:15: SID API Synology = [vbdygo2fMmSXXXXXXXXXXXXX] [ERROR] 14:29:16: line 108: attempt to concatenate global 'load_mem' (a nil value) [DEBUG] 14:39:16: Version API Synology OK [DEBUG] 14:39:16: Chemin API Synology = auth.cgi [DEBUG] 14:39:17: SID API Synology = [I4lBzt7XjBQXXXXXXXXXXXX] [ERROR] 14:39:18: line 108: attempt to concatenate global 'load_mem' (a nil value) [DEBUG] 14:46:21: Version API Synology OK [DEBUG] 14:46:21: Chemin API Synology = auth.cgi [DEBUG] 14:46:21: SID API Synology = [xlvYDXcq6sVzQXXXXXXXXX] [ERROR] 14:46:23: line 108: attempt to concatenate global 'load_mem' (a nil value)
merci Lazer pour la mise à jour
Merci pour ton code ça ma bien aidé
Merci pour l'info
domo a répondu à un(e) sujet de Moicphil dans Périphériques et matériels autres
Pour ceux que ça intéresse chez domadoo ils en reste quelques uns en re conditionné -
merci pour le partage de ce plugin fonctionne nickel
- 329 réponses
Oui impec Did
merci a tous mais c'est pas ça que je cherche c'est a peu près le meme icône qu'il y a en tuto sur le plugin freebox v6 sur domotique info
bonjour à tous je cherche des icônes de freebox si quelqu'un à ça merci de partager j'ai pas trouvé a part free sms
salut à tous j'ai enfin réussi a faire fonctionner le google calendar maintenant c'est bon pour moi
merci Did
J'ai lu l'article c'est intéressant
J'ai la station depuis début mai 2016 et j'ai pas encore changé les piles
Merci pour la mise à jour 4.2 fonctionne très bien
