Moicphil
Hc2 Et Hc Lite- V4.100 - Stable - 29/09/2016
Version 4.100 - Stable
This update features migration process from version 3.600, reconfiguring every device, adjusting it for changes which took place in the system. This will assure a possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please, refer to the message that appears in the interface and Notification Center for further instructions after finishing upgrade.
Important!
Updating from version 3.600 may take up to 30 minutes, please do not restart controller during update process.
Resolved issues:
- Charts in Consumption Panel are not aligned.
- Firmware Update changelog is not displayed sometimes.
- Lack of translations in Diagnostic Panel.
- Magic Scene featuring removed device is inoperable.
- Magic Scene triggered by battery level is not working.
- floating point numbers are not displayed correctly on Virtual Devices labels.
- Some special characters in Magic Scene name may preclude them from saving.
- Occasional 503 error after activating Virtual Device buttons.
- Alarm Panel is blank if no devices are added.
- Lack of parameters templates for languages different than English and Polish.
- After several requests sent from Virtual Device no more requests are sent (e.g. when controlling Global Cache).
- Device can not be disarmed from scene.
New devices support:
- Enerwave ZWN SC7 version 1.5.
- Leviton VRCZ4 version 0.2.
- Aspier RF 5 Scene Controller.
- RFID Readers: BeNext, Wintop, Zipato.
- FGKF-601.
- FGCD-001.
- FGWP-102.
- Sensative Strip versions: 0.0, 0.4, 0.5.
- Vision Security Wirelees, Siren VISEZM1601 versions: 15.5, 15.10.
- Remotec Technology Ltd, Remotec ZXT120 version 1.2.
- Poly control, Danalock versions: 1.2, 1.4.
- Philio Technology Corp, Philio Tech PAN11 versions: 1.1, 1.2.
- GreenWave, PowerNode, versions: 4.20, 4.28.
Other improvements:
- Multiple RGBW devices can be grouped and controlled as one (both with interface and physical switches). Integration is possible in Advanced Configuration of one of RGBW Controllers.
- After adding Dimmer, Relay Switch, Wallplug, Roller Shutter or RGBW Controller user can choose controlled device type with pop-up.
- Removing device with cross icon from device tile triggers Z-Wave removing process, with possibility of forcing it.
- Improved scene information, number of running instances and scene triggered information are displayed on bottom of scene tile.
- Update availability is checked on Home Center booting.
- Rooms without devices assigned are displayed in Home, Scenes and Devices tab.
- RGBW color can now be set in Magic Scenes.
- New filters for displaying hidden devices on Devices tab.
- Power management notifications are now visible in Notification Center, for devices that are capable of sending them. e.g. Fibaro Dimmer 2, Fibaro Switch 2.
- Z-Wave chip malfunction notification is displayed in Notification Center in case of such event.
- New action in Magic Scenes, controlling of lights or roller shutters in rooms.
- Undesired interface caching effect was reduced significantly. Change is applied once cache is cleared.
Alors messieurs, personne n'a encore cliqué ? àpart @quadal ?
Ahh cool, ferai ça ce soir. Bon boulot Fibaro !
Fait. Un 503 au redémarrage, après téléchargement, qui a nécessité un reboot et c'est bien reparti...
Je ne sais pas si cela est lié àcette version mais j'ai des scènes déclenchées par des devices qui ne s'exécutent, pas de temps en temps.
je viens de la lancer sur mon hcl, j'ai eu une erreur 503 tout de suite...
je sais pas si c'est normal alors j'attend un moment ...
Fait
Err 503, j'ai du redémarrer les services pour que ça fonctionne mais c'est peut être du à  mes problèmes depuis 3 semaines ( err503 tout les matins ) .
A suivre
Erreur 503 10 secondes après le première démarrage, redémarrage des services et depuis une heure environ, ça va.
cela àcorrigé presque tout mes problèmes immédiats (on verra pour les soucis qui arrivent après 3 jours de fonctionnent).
il me reste toujours le soucis de la pièce "Cellier" qui passe en deuxième position après un redémarrage alors que ça place est en 13 position, en bas sur l'interface Web.
Euh presque 2 ans pour avoir une v4 presque acceptable. Il ne faut pas oublier que nous n'avons toujours pas les plugins utilisateurs donc pour moi 2 ans pour corriger une partie des bugs je dirai plutôt doucement le matin et pas trop vite l'après midi.
  • Upvote 8
maj faite
certains modules ont un acces forbiden 403 comme les wall plugs par exemple :11:
qq jours plus tard tout semble avoir disparu
on dirait que tout fonctionne
Et oui Pascal, mais bon la V4 a pas ma évolué depuis tout de même ! Et les fakes devices me font oublier en partie les plugins persos, mais cela viendra. En tout cas on va dans le bon sens, et c'est une bonne nouvelle !
la greenwave, c'est la multiprise ou les prises seules à  votre avis ?
 Mise à  jour effectuée.
RAS pour l'instant.
Bonne nuit.
Vous allez me donner envie de quitter ma 3.601 à  force 😄
C'est vrai que le passage de la v3.6 a v4.1 sent bon pour l'instant
Ayant une grosse base de VD et Scene, pensez-vous qu'il vaut mieux attendre ou sauter le pas sans risque ?
Y aura t-il du travail d'adaptation dans les VD Virtuel & Scene pour un bon fonctionnement, et ayant peu de GEA ?
MERCI
Moi je pense qu'il faut y aller là . Car plus vous attendrez, plus cela deviendra compliqué...
Impossible de garantir qu'il n'y aura pas 2-3 adaptations de VDs à  faire (Par exemple GEA, penser à  utiliser la version v4). Mais niveau stabilité, désormais c'est ok sur la box elle même.
