Lazer
HC2 & HCL - 4.503 - BETA - 28/06/2018
Version 4.503 Beta
This update introduces new and optimized operating system, modified file structure and the following brand new features:
  • Update package downloaded in the background, without locking the interface.
  • Creating encrypted local backup that can be downloaded to your hard drive and later restored.
  • Creating encrypted backups, stored in Fibaro cloud that can be later restored.
  • Customized icons included to backup.
  • Restoring backup with full rollback (restores also software version) or with current software version (up from 4.503). Backups created so far become incompatible.
Changes related to GDPR:
  • Displaying the number of remaining attempts to log in.
  • Blocking the possiblity to log in for 30 minutes after 5 unsuccessful attempts from a given IP address.
  • Displaying the value of time remaining to unlock the ability to log in.
  • E-mail notification sent to admin after 5 unsuccessful attempts to log in.
  • E-mail message sent every 90 days that recommends changing your password.
Other improvements:
  • New, more reliable file structure.
  • No need to use the recovery pendrive.
  • Optimized software update process minimizing the risk of potential errors during system update.
  • Easier and more intuitive setting of advanced parameters.
  • Information about scenes used by a given device available in its configuration.
  • Notification after successful update recommending to create a backup if there is no compatible backup.
  • Possibility to disable creating auto-backup in Fibaro cloud before performing update.
  • Indication after exceeding 90% of cloud backup storage.
  • Compatibility with cameras connecting through https protocol.
  • Added support for FIBARO Wall Plug UK - type G.
  • Adding a time zone for Kuwait.
Resolved issues:
  • Losing the synchronization of the set time.
  • No variables list while creating a virtual device.
  • No icon change lock via the remote access.
  • Switching a number of grouped devices results in 503 error.
  • Non-admin users cannot modify their own e-mail address and password.
  • Number of devices counted in a particular backup contains all endpoints, active plugins and users instead of devices only.
  • Notification suggesting replacing the battery of FIBARO The Heat Controller instead of charging.
  • Scene based on time condition results in 'timer handler failed with error' message.
  • No possibility to set time manually.
  • No power consumption bars in 'Top 5' section.
  • Other minor fixes.
Mise à jour HC-Lite : utiliser l'astuce présentée par @le citron vert :
Modifié par Lazer
Il y a du lourd dans les nouveautés :D
Méfiance avant la mise à jour
Cette fois j'attends la prochaine stable. Trop lourd comme changements.
il y a 34 minutes, Lazer a dit :
Magnifique ;-)
Tardif mais magnifique ;-) et les 2 solutions : Hard drive ou/et cloud apportent de la souplesse
il y a 35 minutes, Lazer a dit :
Ca moi, ca me s...hihihi la politique de changement de mot de passe..ca oblige à l'ecrire sur un papier ;-) vive la sécu ;-)
il y a 39 minutes, Lazer a dit :
bien bien ;-)
Ont-ils enfin activé "NTPD" , quel suspens ;-)
Allez tout ceux qui ont une box de test,on clique et on informe les copains ;-)
il y a 5 minutes, le citron vert a dit :
impossible de l'installer sur hcl
Heuu, d'après le titre, ce n'est que pour HC2 ;-), le firmware béta pour HCL est déjà passé non ? ;-)
Oui ça fait beaucoup pour une bêta je trouve
Envoyé de mon SM-A520F en utilisant Tapatalk
Bonsoir,
Plutôt lecteur du forum sans jamais participer (no time ^^), petit retour d'expérience de cette MAJ.
A noter que j'ai fait la MAJ car :
1. Ma clé recovery est HS et j'en ai marre de pas avoir de backups
2. Le support tech Fibaro après avoir pris la main sur mon HC2 pendant une journée entière m'a confirmé qu'ils n'arrivaient pas du tout à faire quoi que se soit et qu'il m'était impossible de faire un backup (sans renvoi de la box). J'ai jamais renvoyé la box, c'est relou.
3. Je suis prés à tout casser et passer sur Jeedom si je perd mon HC2.
Si c'est clairement risqué à la vue du change log. D'ailleurs la suite le confirme :))
Tentative 1 : "Update Success" quasi immédiat (<30s). Après le reboot, aucune MAJ appliquée. Le contraire m'aurait étonné.
Tentative 2 : Mise à jour. Au bout de plusieurs minutes je m'aperçois qu'il y a des erreurs javascript dans la console qui n'indiquent rien de bon. Un nouvel onglet ouvert vers mon HC2 m'indique que le serveur web répond qu'avec des 404 et la MAJ ne semble plus tourner. -> Reboot forcé
Au reboot :
- Recovery automatique
- Suivi d'un reboot automatique
- Suivi d'un "Update in progress" au bout de 5 minutes, nouvelles erreurs JS et la progressbar est bloquée à un truc comme  80% je dirais
- J'ouvre un nouvel onglet et je suis sur l'authentification
... Connexion ....
... Roulement de tambours ...
- HC 2 4.503 BETA youhouuu :)
Pour la suite, concernant mon problème de backups :
- Direction la page des backups
- Il y a bien "Cloud Backup" et "Local Backup" avec la possibilité de télécharger le backup
- Cloud Backup : Apparemment on a 500mo offert (non testé)
- Local Backup : Je l'exécute immédiatement, au bout de 2 minutes j'obtiens mon backup et il est archivé en sécurité ailleurs désormais :)
Conclusion : Sympa la MAJ ne serait-ce qu'à cause des nouveautés liés aux backups et que la clé n'est plus utile surtout !!!
5b35044fdef08_Capturedecran2018-06-28a17_52_29.thumb.png.7e76208c1b22b356f952a6e0ac3e6c96.png
Modifié par kevin39
Avec une version pareille, c'est l'erreur 503 assurée !!!
Bizarre de passer de 4.180 à 4.503.
C'est vrai que chez Fibaro rien ne nous surprend plus !!! :D
il y a 10 minutes, pepite a dit :
la dernière version beta pour HCL est la 4.501 beta => mais elle bug trop
Pour la 4.503 cette version est proposé en maj , mais elle n'est pas compatible
La mienne Reboote avec un sending discover qui ne donne ... rien. maintenant elle fait un recovery ... toute seule.
C'est quoi ce serviceUpdate ?
 982   980 root     S     129m  13%   1% /opt/fibaro/Zwave
  509   507 root     S    25860   3%   1% /opt/fibaro/GPIOServer
 1588     1 root     S    55256   5%   0% /usr/sbin/asterisk
  527   526 root     S     268m  27%   0% /opt/fibaro/HCServer
  342     1 root     S     5104   1%   0% /usr/sbin/lighttpd -f /etc/lighttpd/lighttpd.conf
 5108  5097 root     R     2800   0%   0% top
 3965   527 root     S    47860   5%   0% /opt/fibaro/ServiceUpdate
  347   346 www-data S     5188   1%   0% nginx: worker process
Modifié par Massalia
La MAJ passe par un recovery qui est fait au reboot,et qui prends BEAUCOUP de temps.
Elle a fini par démarrer.
Tout les "vieux" backup sont inutilisables.
Il y a 1 heure, pepite a dit :
Gros +1, les pseudo admins sécurités n'ont pas compris que ce genre de politique est contre productive et abouti à des mots de passes génériques et ultra basiques composés de PassordXXX et AzertyXXX, les XXX étant une suite de nombre basé sur le mois en cours.
On a les même dans mon entreprise, et chez pas mal de mes clients....
Il y a 2 heures, Lazer a dit :
Ça c'est quand même le Graal, qu'on a cherché en vain pendant des années :13:
il y a 46 minutes, Massalia a dit :
C'est le service qui vérifie les mises à jour de firmware OTA des modules, ce n'est pas nouveau de cette version.
Bon aller je vais la mettre sur ma box de test.
J'ai un module Z-Wave sous la main, je pourrai tester une inclusion ensuite.
Maj passée sans encombre et extra les backups :-)
On se retrouve avec un beau fichier en .fbi backup_HC2-0XXXXXX_2018_06_28-19_31_53.fbi
Mince alors, les Chinois du FBI vont nous espionner :ph34r:
Les fichiers .fbi c'est des fichier 7Z
Merci Lazer pour toutes ces explications.
Bon, pour moi, je patiente une semaine.
Ma prod fonctionne bien, je vais attendre le retour des personnes qui ont une box de test
merci àvous
Si je comprend bien, leur clé recovery ne servira plus a rien donc a l'avenir ?
ils ont enfin compris que renvoyer des boxs en pologne pour une connerie leur était préjudiciable ?
Et ben ...
Avant les vacances d été. Ça me parait très risque de mettre à jour.
Je passe mon tour.
Pas de problème avec les modules Qubino fil pilote à la suite de cette MAJ ? Je me tâte à la faire :)
il y a 9 minutes, schwinny a dit :
Je suppose la même chose, mais attendons de tester et d'avoir un peu d'expérience avant d'en tirer des conclusions définitives.
La clé recovery ne semble plus nécessaire pour la sécurité de la box, mais elle restera toujours utile pour le recovery lui-même, c'est à dire le reset usine sans renvoyer la box en Pologne. Et ça c'est quand même un énorme avantage sur les box concurrentes (*) ... et en fait, quand on y réfléchi, cette clé recovery étant un argument de vente mis en avant sur le site Web de Fibaro. En fait, elle retrouve juste sa fonction première, et rien de plus :)
(*) chez Jeedom, une procédure existe pour générer une clé manuellement et réinitialiser sa box.
Dans un autre domaine, le même genre de procédure existe aussi pour les routeurs Ubiquiti, ou les smartphones.
Mais ça reste du manuel, ce n'est pas à la porté de tout le monde.
Ah ouais, gros gros gros update, monstrueux, une fois de plus, la majorité du travail se trouve dans le "Other minor fixes"
Nouvelle distribution Linux, personnalisation de la banière de connexion, nouvelle clé SSH, nouveau kernel, etc
Using username "root".
#                    Welcome to Fibaro HC2 - Recovery                    #
#  ALERT! You are entering a secured area! Your IP and login information #
#       have been recorded. System administration has been notified.     #
# This system is restricted to authorized access only. All activities on #
# this system are recorded and logged. Unauthorized access will be fully #
# investigated and reported to the appropriate law enforcement agencies. #
# cat /etc/issue
Welcome to the HC2-buildroot recovery system.
# uname -a
Linux HC2-0XXXXX 4.2.0 #1 SMP Thu Feb 22 12:39:21 CET 2018 i686 GNU/Linux
Et tenez vous bien, ils ont tenu leur promesse :
# ps -ef | grep ntp
  459 root     /usr/sbin/ntpd -g
 2632 root     grep ntp
Adieu les problèmes de synchro d'heure :D
Nouveau partitionnement du disque interne (pour rappel, clé USB à mémoire Flash SLC) :
# df -h
Filesystem      Size  Used Avail Use% Mounted on
devtmpfs        494M     0  494M   0% /dev
/dev/sdb2       443M  246M  170M  60% /
tmpfs           496M     0  496M   0% /dev/shm
tmpfs           496M   48K  496M   1% /tmp
tmpfs           496M  204K  496M   1% /run
/dev/sdb3       550M   72M  438M  15% /mnt/download
/dev/sdb5       6.3M   78K  5.7M   2% /mnt/nvm
/dev/sdb6       6.3M   87K  5.7M   2% /mnt/hw_data
/dev/sdb9       301M  4.8M  277M   2% /mnt/user_data
/dev/sdb8       175M  2.3M  159M   2% /mnt/event_data
etc...
Cette version méritait de s'appeler v5.
  • Like 3
va vraiment falloir que je regarde pour le root de la hc2 :P
Bah du coup, vu toutes les modifs cachées au niveau système, le root semble moins utile
Les gros avantages du root, c'était :
- faire tourner NTP
- faire des backups sur support externe
- sauvegarder les icones
- redémarrer les service manuellement en cas de plantage
Il n'y a plus vraiment besoin de tout cela.
  • Like 3
